Enables the trigger update mechanism. Triggered updates are a mechanism for immediately notifying a router‘s neighbors when the router adds or deletes routes or changes their metric.
| vlan-name | Specifies an IPv6 configured VLAN. |
| tunnel_name | Specifies an IPv6 tunnel. |
| all | Specifies all interfaces. |
Enabled.
Triggered updates occur whenever a router changes the metric for a route and it is required to send an update message immediately, even if it is not yet time for a regular update message to be sent. This will generally result in faster convergence, but may also result in more RIPng-related traffic.
The following command enables the trigger update mechanism on all IPv6 configured interfaces:
enable ripng triggerupdate
This command is available on platforms with an Edge, Advanced Edge, or Core license. For licensing information, see the Switch Engine v33.1.1 Licensing Guide document.
